If you own a Tern GSD, HSD, or Quick Haul, you may have experienced the guide pulley prematurely wearing down. Tern has released a new pulley setup that looks more like a derailleur guide pulley and should wear much longer with your chain. This works on the chain versions of the following bikes: GSD (Gen 1 and 2), HSD (Gen 1 and 2), Orox, Quick Haul, Quick Haul Long, and Short Haul
Replacement guide pulley part: A.07004.0094.03.00
Purchase online or your local Tern dealer
Have any questions? Let me know!
Tern Pulley Part Numbers
Complete setup for the first install: F.07004.0027.00.00Replacement guide pulley part: A.07004.0094.03.00
Installing New Pulley Parts
For GSD Gen 1 S10 and S00
- 45mm bolt
- 12mm washer
- Guide wheel with u-clip installed over
- 10mm bushing
- Slide onto the frame and add grease
2. 12mm washer - M6 stainless steel nut tightened down
- 1/4 inch spring washer
- M6 locknut tightened down
For GSD Gen 2 S10
- 55mm bolt
- 12mm washer
- Slide on to frame
- 10mm bushing x2
- 12 mm washer
- Grease
