This is a rundown of all GSD Gen 2 parts lists we can find info on!
Tern GSD Gen 2 S10 Parts List
Tern GSD Gen 2 S00 Parts List
Tern GSD Gen 2 R14 Parts List
There are 2 GSD Gen 2 S10 versions - LR and LX—with differences noted below.
Frame & Fork
- Frame – Tern GSD, 6061-AL, patented MultiTruss design, EFBE Tri-Test approved: 200 kg
- Fork – Suntour custom for Tern, 1.5" tapered Chromoly steerer, 32 mm stanchions, Thru-axle, 70 mm travel, EFBE approved: 200 kg
Cockpit
- Grips – Standard
- Handlebar – Tern Back Sweep, 660 mm, Black (SKU: A.02006.0043.03.04)
- Stem – Andros Gen 2, Black w/ Silver Stripes (SKU: A.02007.0038.03.04)
- Headset – 1-1/8 to 1.5 Tapered, Angular Contact Bearings (SKU: A.02010.0024.00.00)
- Saddle – GSD, Black/Grey w/ Handle (SKU: A.02013.0069.00.00)
- Seatpost (Lower) – Telescopic, 34.9x285 mm, Black (SKU: A.02014.0051.03.00)
- Seatpost (Upper) for LX – Cane Creek Thudbuster G4, 30.9x375 mm
- Seatpost Clamp (Upper) – 30.9 mm, Black (SKU: F.02015.0010.03.00)
- Seatpost Clamp (Lower) – 34.9 mm, ID: 37 mm, Black (SKU: A.02015.0021.03.01)
Brakes
- Brake Lever – Magura MT5e, Normally Open, Higo Connector, 950 mm (SKU: F.04003.0008.03.00)
- Front Brake – Magura MT5, 3-Finger Lever w/ Switch, Higo, 950 mm Cable, 1100 mm Housing (SKU: 87251700135)
- Rear Brake – Magura MT5, 950 mm Cable, 2400 mm Housing, 2100 mm Assembly (SKU: 87251700136)
- Rotor Front – Magura, 180 mm, 6-Bolt (SKU: 80002500043)
- Rotor Rear – Magura, 180 mm, 6-Bolt (SKU: 82222500090)
Wheels
- Front Hub – Glory Disc, 32H, 100 mm, Black (SKU: A.03001.0166.03.01)
- Rear Hub – Glory, 10-Speed, 32H, 148 mm, Black (SKU: A.03001.0168.03.01)
- Cassette Body – Freehub Kit for GSD Gen 2 (SKU: F.03002.0005.00.00)
- End Cap – Front Hub (SKU: F.03002.0007.00.00)
- Front Thru Axle – 100 mm x 15 mm, Black (SKU: F.03002.0004.03.00)
- Rear Thru Axle – 177 mm, M12, Black (SKU: A.03002.0063.03.00)
- Front Rim Set – Tern Atlas, 20"x32H, 36 mm wide, Black (SKU: F.01002.0077.00.00)
- Rear Rim Set – Tern Atlas, 20"x32H, 10-Speed, 148 mm, Black (SKU: F.01003.0115.00.00)
- Front Rim – 20"x32H, 406x36, A/V, 13G, Black (SKU: A.03006.0171.03.00)
- Rear Rim – 20"x36H, 406x36, A/V, 13G, Black w/ Atlas Logo (SKU: A.03006.0172.03.00)
- Spokes Front (Drive) – 172 mm, 13G,
- Spokes Front (Non-Drive) – 173 mm, 13G
- Spokes Rear (Drive) – 172 mm, 13G,
- Spokes Rear (Non-Drive) – 174 mm, 13G
- Nipples – 13 mm, 13G
- Tires Front – Schwalbe Big Ben Plus, 55-406, 20x2.15
- Tires Rear – Schwalbe Super Moto-X, 62-406, 20x2.40
Drivetrain
- Crank Arms – GSD Gen 2, Right/Left (SKU: A.04011.0009.03.04)
- Chainring Spider – BCD 130 mm (SKU: F.10001.0075.03.04)
- Chainring – GSD S10 Gen 2, 52T, NWP307, M8*14.0L (SKU: F.04010.0012.03.00)
- Chain – KMC e10T Turbo, EPT Anti-Rust, 10-Speed, 170 Link
- Cassette – Shimano Deore CS-M4100-10, 10-Speed, 11-42T
- Rear Derailleur – Shimano Deore RD-M6000 GS, 10-Speed
- Derailleur Hanger – Red & Black Set (SKU: A.07004.0059.00.00)
- Shifter – Shimano Deore SL-M6000-R, 10-Speed, Rapidfire Plus, 2600 mm
- Pedals – Standard
Electric & Wiring
- Light Cable (Front) – Bosch, 1400 mm (SKU: 1270.020.322)
- Light Cable (Rear) – Bosch, 1400 mm (SKU: 1270.020.324)
- LX Model Lighting
- Front Light– Ignis Z3EK Pro, rev2022 (SKU: F.05005.0003.03.00)
- Light Remote – RB5 Remote Button, Magura Clamp (SKU: F.05005.0004.03.00)
- Rear Light Set – GSD Gen 2, w/ Brake Light (SKU: A.05005.0036.00.00)
- Rear Light (R3EK) – w/ M4 Bolt + Washer, rev2022 (SKU: A.05005.0043.00.00)
Misc
- Speed Sensor Cable – Bosch, 800 mm
- Battery Lock – ABUS DT2 T82, Keyed-Alike
- Mudguards – 20", Black, GSD Gen 2 (SKU: F.05002.0008.03.00)
- Plastic Clip – GSD Gen 2, for Wheel Guards (SKU: A.10001.0108.00.00)
- Plastic Flat Strip – GSD Gen 2, for Integrated Lower Decks (SKU: A.10001.0109.00.00)
- Rack Plug – GSD, HSD, NBD, Vektron (SKU: A.02009.0009.03.00)
- Wheel Guard Set – GSD Gen 2, Black (SKU: A.10001.0107.00.00)
- Vertical Parking Support – EPDM, Black (SKU: F.07004.0013.03.00)
- Light Bracket – Ignis, Handlebar Mount (SKU: F.07004.0026.03.00)
- Cable Clamp – Physis, 15 mm, Plastic, Black (SKU: A.10001.0010.00.00)
- Ball Head Screw – Physis Handlepost (SKU: A.02018.0005.00.00)
Frame & Fork
Cockpit
- Grips – Ergon
- Headset – 1-1/8" to 1.5" Tapered, Angular Contact Bearings (SKU: A.02010.0024.00.00)
- Seatpost (Lower) – Telescopic, 34.9 x 285 mm, Black (SKU: A.02014.0051.03.00)
- Seatpost (Upper) – Cane Creek Thudbuster G4, 30.9 x 375 mm
- Seatpost Clamp (Lower) – 34.9 mm, ID 37 mm, Black (SKU: A.02015.0021.03.01)
Brakes
- Brake Lever – Magura MT5e, Normally Open (NO), HIGO Connector, 950 mm
- Front Brake – Magura MT5, 3-Finger Lever w/ Switch, 950 mm Cable, 1100 mm Housing
- Rear Brake – Magura MT5, 3-Finger Lever w/ Switch, 950 mm Cable, 2400 mm Housing, 2100 mm Assembly
Wheels
- Front Hub – Glory Disc, 32H, OLD: 100 mm, Black (SKU: A.03001.0166.03.01)
- Rear Hub – Enviolo Heavy Duty, Modular Axle, 36H, 40T Spline (SKU: CVP-HD-MA-36-DC-OE)
- Spacer – Right Side Enviolo Hub (SKU: A.03002.0075.00.00)
- Spacer – Left Side Enviolo Hub (SKU: A.03002.0074.00.00)
- Cap Screw – Enviolo Hub (SKU: A.03002.0073.00.00)
- Front Thru Axle – 100 mm x Ø15 mm
- Rear Rim Set – Tern Atlas, 20"x36H, Enviolo SP CVP, Black (SKU: F.01003.0116.00.00)
- Front Spokes – 172–173 mm, 13G
- Rear Spokes – 149 mm, 13G
Drivetrain
- Belt – Gates CDX, 174T, 11M-174T-12CT
- Rear Cog – Gates CDX, 24T, Enviolo Compatible
- Shifter – Enviolo Twist Pure w/ Display, 2500 mm
- Rear Derailleur Hanger – Red & Black Set (SKU: A.07004.0059.00.00)
- Pedals – standard
Misc
- Rubber Bumper Kit for Lockstand – Atlas Lockstand, GSD Gen 2, Black (SKU: F.07004.0018.03.01)
- Battery Lock – ABUS DT2 T82, Keyed-Alike, 68437
- Flat Strip – GSD Gen 2, for Integrated Lower Decks (SKU: A.10001.0109.00.00)
- Cable Clamp – Physis Handlepost, 15 mm, Black (SKU: A.10001.0010.00.00)
- Ball Head Screw – Physis Handlepost, Silver (SKU: A.02018.0005.00.00)
- Chain Guard – CLite, GSD Gen 2, Black (SKU: F.02031.0008.03.00)
- Chain Tensioner – Belt Drive, GSD Gen 2, Black (SKU: A.07004.0077.00.00)
- Bushing – For Chain Tensioner, igus, Black (SKU: A.07004.0080.00.00)
- Brass Bell – GSD Gen 2 (SKU: A.05007.0015.00.00)
Lighting
- Bosch Light Cable (Front) – 1400 mm
- Bosch Light Cable (Rear) – 1400 mm
- Front Light – Ignis Z3EK Pro, rev2022 (SKU: F.05005.0003.03.00)
- Light Remote – RB5 Remote, Magura Clamp (SKU: F.05005.0004.03.00)
- Front Ignis Light Set (LX) – GSD Gen 2 (SKU: A.05005.0035.00.00)
- Rear Light Set – GSD Gen 2 w/ Brake Light (SKU: A.05005.0036.00.00)
- E-Wiring Front – Higo 3T1 Adapter Cable (SKU: A.06005.0027.00.00)
- E-Wiring Rear – Higo 2T2 Adapter Cable (SKU: A.06005.0029.00.00)
- E-Wiring Y-Cable – Brake Signal (SKU: A.06005.0028.00.00)
- Light Source Cable – Bosch BES2 (SKU: F.05005.0007.03.00)
- E-Wiring – Valo-RoximG2, 1250L (SKU: A.06005.0030.00.00)
Frame & Fork
Cockpit
- Grips – Standard
- Seatpost Clamp – 34.9 mm, ID 37 mm, Anodized Black (SKU: A.02015.0021.03.01)
Brakes
- Rotor Rear – Magura, 180 mm, Rohloff Mount
Wheels
- Front Hub – Glory Disc, 32H, OLD: 100 mm, Red (SKU: A.03001.0167.06.01)
- Rear Hub – Rohloff Speedhub 500/14 A12 DB OEM2 E14, Red Boost
- Front Thru Axle – 100 mm x Ø15 mm, Black
- Front Rim Set – Atlas, 20"x32H, Red, 36 mm wide (SKU: F.01002.0078.00.00)
- Rear Rim – 20"x36H, 406x36, A/V, 14G, Black, Atlas Logo (SKU: A.03006.0173.03.00)
- Rear Spoke (Drive) - Rohloff, L 146 mm, 2.0/1.8/2.0, w/Nipples, 14G
- Rear Spoke (Non Drive) - Rohloff, L 146 mm, 2.0/1.8/2.0, w/Nipples, 14G
Drivetrain
- Belt – Gates CDX, 174T, 11M-174T-12CT (SKU: 92551077)
- Front Chainring – Gates CDX, 63T, Bosch G4 Compatible, Black Guard (SKU: 78700447)
- Rear Cog – Gates CDX:EXP, 19T, Rohloff Spline (SKU: 78980574)
- Shifter – Rohloff E14, Switch Unit (SKU: 8801)
- Pedals – Standard
Lighting
Misc
- Rubber Bumper Kit – Atlas Lockstand, GSD Gen 2, Black (SKU: F.07004.0018.03.01)
