This is initially a test, so please give feedback!
HSD Gen 2 Parts Lists:​
Tern HSD Gen 2 P10 Spec
Tern HSD Gen 2 P5i Spec
Tern HSD Gen 2 S00 Spec
Tern HSD Gen 2 S11 Spec
Tern HSD Gen 2 P10 Parts List
Post your findings for the HSD P10 spec in the comments!
Frame & Fork
  • Frame – Tern HSD, 6061-AL, patented design, Tern sliding dropouts, EFBE Tri-Test approved: 180 kg
  • Fork – Suntour custom for Tern, 1.5" tapered Chromoly steerer, 32 mm stanchions, Thru-axle, 70 mm travel, EFBE approved: 180 kg
Cockpit
  • Display - Bosch Intuvia 100 Instructions
  • Grips – Standard
  • Headset – Tern 1-1/8" to 1.5" Tapered, Angular Contact Bearings (SKU: A.02010.0024.00.00)
  • Headset (HS-T-07) – 1-1/8" Steerer, w/ Star Nut Set, Black (SKU: A.02010.0030.00.00)
  • Handlepost – Not listed (assumed standard HSD-style)
  • Seatpost – Not listed
  • Seatpost Clamp – 34.9 mm Lower Clamp, ID 37–38.1 mm (SKUs: A.02015.0023.03.01 and A.02015.0021.03.01)
  • Saddle – Tern HSD/NBD, Black/Grey (SKU: A.02013.0078.03.00)
Brakes
  • Front Brake – Shimano ALTUS MT200, BL-MT200L / BR-MT200F, 1150 mm hose (SKU: AMT200KLF9RX115)
  • Rear Brake – Shimano ALTUS MT200, BL-MT200R / BR-MT200R, 1800 mm hose (SKU: AMT200KRRXRA180)
  • Rotor Front – Tektro 160 mm 6-bolt (SKU: TR160-52)
  • Rotor Rear – Tektro 180 mm 6-bolt (SKU: TR180-52)
Wheels
  • Front Wheel – 20", Disc, 406x32H, 15x100 mm, Black (SKU: F.01002.0095.03.00)
  • Rear Wheel – 20", Disc, 406x32H, 135 mm, Black (SKU: F.01003.0137.03.00)
  • Rim – 20" x 32H, Doublewall Aluminum, Black (SKU: A.03006.0197.03.14)
  • Cassette Body – HG 11-Speed, Novatec (SKU: F.03002.0003.00.00)
  • Spokes Front (Drive) – 175 mm, 14G, x16
  • Spokes Front (Non-Drive) – 173 mm, 14G, x16
  • Spokes Rear (Drive) – 173 mm, 14G, x16
  • Spokes Rear (Non-Drive) – 176 mm, 14G, x16
  • Nipples – 14 mm, 14G
  • TiresSchwalbe Big Apple K-Guard, 20x2.15
Drivetrain​
  • Crank Arms – Bosch V3, 170 mm, Black (SKU: A.04011.0008.00.00)
  • Chainring – 52T, NWP307, w/o spider (SKU: F.04010.0011.03.00)
  • Pedals – Standard
  • ChainKMC e10S, 10-Speed, 142 Link
  • CassetteShimano Deore HG50-10, 11-36T
  • Chain Guide Pulley – HSD / Quick Haul (SKUs: F.07004.0017.00.00 and A.07004.0050.03.00)
  • Chainguard – HSD Gen 2, w/ Bracket + Hardware, Black (SKU: F.02031.0101.03.00)
  • Rear DerailleurShimano Deore RD-M6000 GS Medium Cage
  • Shifter – Shimano Deore SL-M6000-R, Right, 10-Speed, 2050 mm cable
Misc:​
  • Battery Lock – ABUS T82 style key, Keyed-Alike with frame lock but not compatible with keyed alike program
  • Dropout – Left/Right, HSD Gen 2, Derailleur (SKU: F.07004.0032.03.00)
  • Speed Sensor Cable – Bosch, 815 mm
  • Fenders – SKS 20", Front + Rear, Matte Black
  • Frame Lock – ABUS 4650L, keyed-alike with Bosch battery
  • Kickstand – Ursus Mooi, 225 mm
  • Rack Plug – GSD, HSD, NBD, Vektron
  • Rear Light – R3EK, w/ M4 Bolt + Washer, rev2022
  • Rear Rack – HSD Gen 2, w/ Hardware, Matte Black
Tern HSD Gen 2 P5i Parts List
Frame & Fork
Cockpit
  • Grips – Standard
  • Seatpost Clamp – 34.9 mm, Lower Clamp, ID 37–38.1 mm (SKUs: A.02015.0023.03.01 & A.02015.0021.03.01)
Brakes
  • Front Brake – Shimano ALTUS MT200, 1150 mm hose
  • Rear Brake – Shimano ALTUS MT200, 1800 mm hose
  • Rotor Front – Shimano 180 mm, 6-bolt
  • Rotor Rear – Shimano 160 mm, Center Lock
Wheels
  • Rear Wheel – 20", Disc, 406x32H, 135 mm, Black (SKU: F.01003.0139.00.00)
  • Front Rim – 20"x32H, Doublewall Aluminum, Black (SKU: A.03006.0197.03.14)
  • Rear Rim – 20"x32H, Doublewall Aluminum, Black (SKU: A.03006.0195.03.14)
  • Rear Hub – Shimano NEXUS SG-C7000-5D, 5-Speed, 135 x 187 mm
  • Tires – Schwalbe Big Apple K-Guard, 20x2.15
  • Spokes Rear (Drive) – 163 mm, 14G, x16
  • Spokes Rear (Non-Drive) – 165 mm, 14G, x16
Drivetrain​
  • Front Chainring – Gates CDX 55T, 130 BCD, for Bosch G3 Unified (SKU: 78700118)
  • Belt – Gates CDX, 151T, 11M-151T-12CT (SKU: 92551083)
  • Rear Cog – Gates CDX 30T, for Shimano Nexus 5 (SKU: CT1130YMN-U)
  • Shifter – Shimano Nexus SL-C7000-5, 5-Speed Revoshift, 1850 mm cable (SKU: ASLC70005L185L)
  • Pedals – Standard
Misc​
  • Battery Lock – ABUS BLO BOS DT3 T82, Keyed-Alike with Bosch Battery (SKU: 90744)
  • Chain Guide Pulley – HSD / Quick Haul (SKU: F.07004.0017.00.00)
  • Dropout (Internal Gear) – HSD Gen 2, Left/Right (SKU: F.07004.0031.03.00)
  • Fenders (Aluminum) – 20", Front + Rear, w/ Hardware, Matte Black (SKU: F.05002.0016.03.00)
  • Fenders (SKS) – 20", Front + Rear, w/ Hardware, Matte Black (SKU: F.05002.0017.03.00)
  • Frame Lock – ABUS 4650L, Keyed-Alike with Bosch Battery (SKU: 4650L)
  • Head Badge – OD 50 mm, Curved, Silver (SKU: A.05009.0033.01.00)
  • Kickstand – Ursus Mooi, 225 mm, Black (SKU: F.02017.0016.03.00)
  • Rack Plug – GSD, HSD, NBD, Vektron (SKU: A.02009.0009.03.00)
  • Rear Light – R3EK, w/ M4 Bolt + Washer, rev2022 (SKU: A.05005.0043.00.00)
  • Rear Rack – HSD Gen 2, w/ Hardware, Matte Black (SKU: A.05004.0077.03.12)
Tern HSD Gen 2 S00 Parts List
Frame & Fork
Cockpit
  • Display - Bosch Kiox 300
  • Grips – Standard
  • Seatpost (Lower) – Tern Telescopic, 34.9 x 285 mm, Black (SKU: A.02014.0051.03.00)
  • Seatpost (Upper) – Cane Creek Thudbuster G4, 30.9 x 375 mm
  • Seatpost Clamp – 34.9 mm Lower Clamp, ID 37–38.1 mm (SKUs: A.02015.0023.03.01 & A.02015.0021.03.01)
Brakes
  • Front Brake – Magura MT4N-e, 3-Finger Lever w/ Switch, Higo Mini B Plug, 950 mm Cable, w/ PM160–180 Adapter
  • Rear Brake – Magura MT4N-e, 3-Finger Lever w/ Switch, Higo Mini B Plug, 950 mm Cable, 2100 mm Housing
  • Rotor Front – Magura, 180 mm, 6-bolt
  • Rotor Rear – Magura, 160 mm, 6-bolt
Wheels
  • Rear Wheel – 20", Disc, 406x36H, 135 mm, Black (SKU: F.01003.0138.03.00)
  • Rear Rim (Enviolo) – 20"x36H, Doublewall Aluminum, Black (SKU: A.03006.0196.03.14)
  • Rear Hub – Enviolo Heavy Duty, Solid Axle, 36H, Disc, 40T Spline (SKU: CVP-HD-SA-36-DC-OE)
  • Tires – Schwalbe Big Ben RaceGuard, 20x2.15, Wire Bead
  • Spokes Rear (Drive) – 150 mm, 14G, x18
  • Spokes Rear (Non-Drive) – 150 mm, 14G, x18
Drivetrain​
  • Front Chainring – Gates CDX 60T, 130 BCD, for Bosch GEN3 Unified, 45.5 mm Offset
  • Rear Cog – Gates CDX 22T, for Enviolo
  • Shifter – Enviolo Twist Shifter, 2500 mm Cable
  • Pedals – Standard
Misc​
  • Battery Lock – ABUS BLO BOS DT3 T82, Keyed-Alike with Bosch Battery but not able to key alike to locks
  • Bracket – Light Bracket for Ignis, Handlebar Mount (SKU: F.07004.0026.03.00)
  • E-Wiring (Rear) – Higo 2T2 Adapter Cable (SKU: A.06005.0029.00.00)
  • E-Wiring (Front) – Higo 3T1 Adapter Cable (SKU: A.06005.0027.00.00)
  • Speed Sensor Cable – Bosch, 815 mm (SKU: EB11.200.012)
  • Light Wiring – Higo Y-Cable for Brake Signal (SKU: A.06005.0028.00.00)
  • Light Wiring – Electric Source Cable for Bosch BES3 (SKU: A.05005.0044.00.00)
  • Front Light – Ignis Z3EK Pro, rev2022 (SKU: F.05005.0003.03.00)
  • Light Remote – RB5 Remote Button, Magura Clamp, for Ignis Light (SKU: F.05005.0004.03.00)
Tern HSD Gen 2 S11 Parts List
Frame & Fork
Cockpit
  • Grips – Standard
Brakes
  • Front Brake – Magura MT4N-e, 3-Finger Lever w/ Switch, Higo Mini B Plug, 950 mm Cable, 1150 mm Housing, PM160–180 Adapter
  • Rear Brake – Magura MT4N-e, 3-Finger Lever w/ Switch, Higo Mini B Plug, 950 mm Cable, 2100 mm Housing, 1800 mm Assembly
Wheels
  • Rim – 20"x32H, Doublewall Aluminum, Black (SKU: A.03006.0197.03.14)
  • Cassette Body – HG, 11-Speed, Novatec (SKU: F.03002.0003.00.00)
Transmission
  • Chainring (w/ Guard) – Bosch V3, 56T, No Crank Arm (SKU: A.04010.0014.00.00)
  • Chainring – 56T, EM20E, M8*5.5L, No Spider (SKU: F.04010.0010.03.00)
  • Chain – KMC e11S, 11-Speed, 144 Link
  • Cassette – SunRace MS8, 11-Speed, 11-36T
  • Chain Guide Pulley – HSD / Quick Haul (SKUs: F.07004.0017.00.00 & A.07004.0050.03.00)
  • Rear Derailleur – Shimano DEORE XT RD-M5120 SGS, 10/11-Speed, Direct Attachment
  • Shifter – Shimano DEORE XT SL-M5100-R, 11-Speed, 2400 mm Cable
  • Pedals – Standard
Misc​
  • Light Bracket – Ignis, Handlebar Mount (SKU: F.07004.0026.03.00)
  • Dropout (Derailleur) – HSD Gen 2, Left/Right (SKU: F.07004.0032.03.00)
  • Light Wiring (Brake Signal) – Higo Y-Cable (SKU: A.06005.0028.00.00)
  • Light Wiring (Power Source) – Bosch BES3 Source Cable (SKU: A.05005.0044.00.00)
